Page 2 of 9
Results 31 to 60 of 256
    Oct 2023
    Afghanistan
    Originally Posted by pauli3 View Post
    Have an example of some of the 1080p content? would be cool to test.
    here you go
    https://www.tvnz.co.nz/shows/liam-lawson-in-the-wings/episodes/s1-e1
    I suspect as the content will have been provided by Red Bull that's why it's 1080.
  2. I must admit I have been tired - for the last day or so I was thinking "Where the hell is the name Ozivine coming from", but now I've had some sleep I realise and I like it at a lot haha.
  3. A missed opportunity to call the tool, "YouLittleRipper".
    Oct 2023
    Afghanistan
    Touche !
    Oct 2023
    Afghanistan
    I had quite a look at this today. It looks like the full sports replays are provided by for TVNZ by a new company MediaKind. The result is they make those files available in a totally different construct (diferent api, mpd, licence server the lot) and from what I could figure out appear to be PlayReady protected - so they're a no go at this stage until I do more research on how that works.
    Haven't had a chance to poke around at your other incorrect shows yet. It's on my to-do list.
    In some good news though, I do have ThreeNow working quite well, so will look to release that in the next few days.
  6. Originally Posted by billybanana View Post
    Thanks for all of your hard work, it is appreciated.
    Oct 2023
    Afghanistan
    I've pushed out v1.3 which adds a new service ThreeNow and also caters for 1080p content in TVNZ (which for now is only full Sport replays).
    The TVNZ updates were the most tricky I have had to deal with so far, in that the 1080p content is hosted in a different construct and also required obtaining a secondary token to access it. Added to my learning curve in a big way.
    ThreeNow does not require login or cookies to use Ozivine but their site does require a login to navigate your way around it. So free account required to perform that.
    New release can be downloaded here https://github.com/billybanana80/ozivine/releases/tag/Ozivine_v1.3 or you can do the git update thing for those that do that.
    Happy downloading
    Oct 2023
    Afghanistan
    You can get this with the new update to v1.3. Some of those replays are massive file sizes, especially Wimbledon.
    Mar 2023
    Australia
    Thanks @billybanana that file worked well.
  10. This may be a cheeky request.. but, would it be possible so that the command line works in a similar way to Freevine, so you type ozvine <url>. This way it would be easy to use the command in a batch file for multiple eps (I do this with Freevine when I want multiple eps of a show but not the entire season, so I can add URLs to a txt file, then just run the batch file I created and it grabs each episode from the txt file).
    I've altered the script slightly already so that it doesn't ask for the yes/no prompt after entering the URL but anything more is over my head. (no major drama if not, it's great just being able to automate from Au/NZ sites so thanks again)
    Oct 2023
    Afghanistan
    Deleted
    Oct 2023
    Afghanistan
    I've pushed out some major changes to the logic behind video identification for TVNZ. Master and the v1.3 release have been updated on GitHub.
    Originally Posted by ringy9 View Post
    Another thing I found was a movie Shrek Forever actually downloaded A Smurf movie and the tv show Heavy metal downloaded a Star Trek episode
    This problem will be solved now. I was able to grab Shrek Forever and others correctly.
    Aug 2023
    Southend On Sea Essex
    Can these service scripts work with your freevine GUI tool as i recall there were Australian spots there previous but the scripts weren't present/improved upon before?
    Oct 2023
    Afghanistan
    Nah totally separate thing. I may end up doing something with Devine or a newer GUI. Dunno I have to think about it for a while yet.
  15. Thanks, this looks great!
    I just tried cloning and get an error with:
    git clone https://github.com/billybanana/ozivine.git ozivine
    but changing it to the below, worked.
    git clone https://github.com/billybanana80/ozivine.git ozivine
    Oct 2023
    Afghanistan
    Ah cool I've updated the README.md now. Bit sad I don't know my own username
  17. Just tried downloading something from Threenow and get the following error:
    Enter the video URL: https://www.threenow.co.nz/shows/dane-simpson%253A-didgeridoozy/dane-simpson---digerid...659/M70452-010
    Ozivine..........initiating ThreeNow
    Error importing or running the service module: Could not find the video ID in the API response.
    The URL for this is - https://www.threenow.co.nz/shows/dane-simpson%253A-didgeridoozy/S4558-659
    Tried it with a few other comedy shows and they didn't work either e.g.
    https://www.threenow.co.nz/shows/luke-heggie%253A-i-already-told-you/S4553-588
    https://www.threenow.co.nz/shows/harley-breen%253A-flat-out/S4557-009
  18. Member
    Oct 2023
    Afghanistan
    Laid up crook at the moment and not in the mood to investigate comedy ! Will have a look in a few days when I'm up to it.
    Mar 2006
    billybanana - Great program/script! Works great. I am having an issue with TVNZ - I do have creds in the config file, cookies, etc. I can DL from SBS and a few others, but TVNZ, nd yes on NZ VPN, I cannot. Keep gettings:
    (venv) C:\oz>python ozivine.py
                                  _       _
                          ___ ___(_)_   _(_)_ __   ___
                         / _ \_  / \ \ / / | '_ \ / _ \
                        | (_) / /| |\ V /| | | | |  __/
                         \___/___|_| \_/ |_|_| |_|\___|
                        Version 1.3 Copyright © 2024 billybanana
    ←[94mEnter the video URL: ←[0mhttps://www.tvnz.co.nz/shows/my-life-is-murder/episodes/s1-e2
    ←[94mOzivine..........initiating TVNZ←[0m
    ←[92mLogin successful, token obtained←[0m
    ←[91mNo 'sources' found in the response←[0m
    (venv) C:\oz>
    Where does this "←[91mNo 'sources' found in the response←[0m" Come from?
    Cookie file is set.
    Where is I take the found keys from Freevine, I can download with N_m3u8DL-RE
    (venv) C:\freevine>N_m3u8DL-RE --key 71790276e17d484f8a0efb9fd6a3fcae:fc50d1414a0f8836c41602977418d4d7 "http://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/bccenc/963482467001/6615ff99-5c10-4203-a04b-ce8be0856116/6s/manifest.mpd?fastly_token=NjZiZDBmY2VfNzE3NWI3ODg0M2E5OWRjNjE5M2JiMDhlMmM4ZmZiMmFlMjQ3YTk4ZTg0YWMwNDYzODUyMDcyZDJmYzVhYTNhNg%3D%3D" --save-name "My Life Is Murder - s01e02" -M format=mkv
    15:13:27.468 INFO : N_m3u8DL-RE (Beta version) 20231113
    15:13:27.493 INFO : Loading URL: http://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/bccenc/963482467001/6615ff99-5c10-4203-a04b-ce8be0856116/6s/manifest.mpd?fastly_token=NjZiZDBmY2VfNzE3NWI3ODg0M2E5OWRjNjE5M2JiMDhlMmM4ZmZiMmFlMjQ3YTk4ZTg0YWMwNDYzODUyMDcyZDJmYzVhYTNhNg%3D%3D
    15:13:28.256 INFO : Content Matched: Dynamic Adaptive Streaming over HTTP
    15:13:28.258 INFO : Parsing streams...
    15:13:28.352 WARN : Writing meta json
    15:13:28.369 INFO : Extracted, there are 8 streams, with 4 basic streams, 3 audio streams, 1 subtitle streams
    15:13:28.371 INFO : Vid *CENC 1280x720 | 2464 Kbps | de600d58-5173-46c0-884c-829e744a27e9 | 25 | avc1.4d001f | 429
    Segments | Main | ~42m54s
    15:13:28.372 INFO : Vid *CENC 1024x576 | 1296 Kbps | 35f64d31-d135-47ae-a1a5-d626cb8ce3a5 | 25 | avc1.4d001f | 429
    15:13:28.373 INFO : Vid *CENC 640x360 | 682 Kbps | 0e910540-22e2-4738-955a-8c4b2d9797b6 | 25 | avc1.4d001e | 429
    15:13:28.374 INFO : Vid *CENC 512x288 | 398 Kbps | d9d9b7b9-8bc9-4d7f-a8f1-35d33756281e | 25 | avc1.420015 | 429
    15:13:28.376 INFO : Aud *CENC a71f69ff-7184-4b10-8ad1-b63b4568b230 | 192 Kbps | mp4a.40.2 | en | 433 Segments | Main |
    ~42m57s
    15:13:28.377 INFO : Aud *CENC 2f1bbbf1-e0c8-4945-9e7d-3303ba8dd03e | 128 Kbps | mp4a.40.2 | en | 433 Segments | Main |
    ~42m57s
    15:13:28.378 INFO : Aud *CENC b0a48066-8d7a-4897-b17f-461d8cf862a0 | 64 Kbps | mp4a.40.2 | en | 433 Segments | Main |
    ~42m57s
    15:13:28.380 INFO : Sub 5ba639d3-fb81-49d2-ae10-846a000c0b23 | en-NZ | 1 Segment | ~42m52s
    15:13:31.614 INFO : Parsing streams...
    15:13:31.621 INFO : Selected streams:
    15:13:31.622 INFO : Vid *CENC 1280x720 | 2464 Kbps | de600d58-5173-46c0-884c-829e744a27e9 | 25 | avc1.4d001f | 429
    15:13:31.623 INFO : Aud *CENC a71f69ff-7184-4b10-8ad1-b63b4568b230 | 192 Kbps | mp4a.40.2 | en | 433 Segments | Main |
    ~42m57s
    15:13:31.624 INFO : Sub 5ba639d3-fb81-49d2-ae10-846a000c0b23 | en-NZ | 1 Segment | ~42m52s
    15:13:31.625 WARN : Writing meta json
    15:13:31.635 INFO : Save Name: My Life Is Murder - s01e02
    15:13:31.636 WARN : MuxAfterDone is detected, binary merging is automatically enabled
    15:13:31.639 INFO : Start downloading...Vid 1280x720 | 2464 Kbps | de600d58-5173-46c0-884c-829e744a27e9 | 25 |
    avc1.4d001f | Main
    15:13:32.181 WARN : Type: cenc
    15:13:32.186 WARN : PSSH(WV): CAESEHF5AnbhfUhPig77n9aj/K4aDXdpZGV2aW5lX3Rlc3QiCDEyMzQ1Njc4MgdkZWZhdWx0
    15:13:32.190 WARN : KID: 71790276e17d484f8a0efb9fd6a3fcae
    15:13:32.192 WARN : Reading media info...
    15:13:32.245 INFO : [0x1]: Video, h264 (avc1), 1280x720
    Vid 1280x720 | 2464 Kbps | 25 | Main ------------------------------ 342/430 79.53% 606.88MB/772.06MB 6.07MBps 00:00:18 \
    Aud 192 Kbps | en | Main             ------------------------------    0/100 0.00%                 -    -     --:--:--
    Sub en-NZ                            ------------------------------    0/100 0.00%                 -    -     --:--:--
    Any ideas? Is my connection on VPN too slow? I have no issue DL directly, just not in ozivine from TVNZ
    Mar 2006
    Originally Posted by ElCap View Post
    good job.
    btw tenplay does do 720p, you just need to modify the m3u8 url
    what modification needs to be done one the url/m3u8 file to get 720p?
    Oct 2023
    Afghanistan
    Yep it's your VPN. I have found TVNZ to be quite picky and problematic in what it accepts and what it doesn't.
    The show itself is fine.
                                  _       _
    Enter the video URL: https://www.tvnz.co.nz/shows/my-life-is-murder/episodes/s1-e2
    MPD URL: http://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/bccenc/963482467001/6615ff99-5c10-4203-a04b-ce8be0856116/6s/manifest.mpd?fastly_token=NjZiZDZkNWRfMzY3ZTNiYjA1OTVhODE4ODhiZmE2NzhhYzIxMDJjOWVmY2Y3NTMyZTJlNmZhNDgwZDRhYzVlN2JlMzExYzU5MA%3D%3D
    License URL: https://manifest.prod.boltdns.net/license/v1/cenc/widevine/963482467001/6615ff99-5c10-4203-a04b-ce8be0856116/71790276-e17d-484f-8a0e-fb9fd6a3fcae?fastly_token=NjZiZDZkNWRfMmU1NDUwZTliY2Y0YmIzYWYxZjUwNDg4MThmYzg3YTJmNDcxYTg0ZGIyNTA2Y2MwMGRkZTFiZjFkOTIyMmNhOA%3D%3D
    PSSH: AAAAVnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADYIARIQcXkCduF9SE+KDvuf1qP8rhoNd2lkZXZpbmVfdGVzdCIIMTIzNDU2NzgyB2RlZmF1bHQ=
    KEYS: --key 71790276e17d484f8a0efb9fd6a3fcae:fc50d1414a0f8836c41602977418d4d7
    DOWNLOAD COMMAND:
    N_m3u8DL-RE "http://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/bccenc/963482467001/6615ff99-5c10-4203-a04b-ce8be0856116/6s/manifest.mpd?fastly_token=NjZiZDZkNWRfMzY3ZTNiYjA1OTVhODE4ODhiZmE2NzhhYzIxMDJjOWVmY2Y3NTMyZTJlNmZhNDgwZDRhYzVlN2JlMzExYzU5MA%3D%3D" --select-video best --select-audio best --select-subtitle all -mt -M format=mkv --save-dir "D:/Downloads/" --save-name "My.Life.Is.Murder.S01E02.720p.TVNZ.WEB-DL.AAC2.0.H.264" --key 71790276e17d484f8a0efb9fd6a3fcae:fc50d1414a0f8836c41602977418d4d7
    Do you wish to download? Y or N: y
    09:47:21.779 INFO : N_m3u8DL-RE (Beta version) 20231113
    09:47:21.797 INFO : Loading URL: http://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/bccenc/963482467001/6615ff99-5c10-4203-a04b-ce8be0856116/6s/manifest.mpd?fastly_token=NjZiZDZkNWRfMzY3ZTNiYjA1OTVhODE4ODhiZmE2NzhhYzIxMDJjOWVmY2Y3NTMyZTJlNmZhNDgwZDRhYzVlN2JlMzExYzU5MA%3D%3D
    09:47:21.987 INFO : Content Matched: Dynamic Adaptive Streaming over HTTP
    09:47:21.988 INFO : Parsing streams...
    09:47:22.026 WARN : Writing meta json
    09:47:22.036 INFO : Extracted, there are 8 streams, with 4 basic streams, 3 audio streams, 1 subtitle streams
    09:47:22.036 INFO : Vid *CENC 1280x720 | 2464 Kbps | de600d58-5173-46c0-884c-829e744a27e9 | 25 | avc1.4d001f | 429
    09:47:22.037 INFO : Vid *CENC 1024x576 | 1296 Kbps | 35f64d31-d135-47ae-a1a5-d626cb8ce3a5 | 25 | avc1.4d001f | 429
    09:47:22.037 INFO : Vid *CENC 640x360 | 682 Kbps | 0e910540-22e2-4738-955a-8c4b2d9797b6 | 25 | avc1.4d001e | 429
    09:47:22.038 INFO : Vid *CENC 512x288 | 398 Kbps | d9d9b7b9-8bc9-4d7f-a8f1-35d33756281e | 25 | avc1.420015 | 429
    09:47:22.038 INFO : Aud *CENC a71f69ff-7184-4b10-8ad1-b63b4568b230 | 192 Kbps | mp4a.40.2 | en | 433 Segments | Main |
    ~42m57s
    09:47:22.039 INFO : Aud *CENC 2f1bbbf1-e0c8-4945-9e7d-3303ba8dd03e | 128 Kbps | mp4a.40.2 | en | 433 Segments | Main |
    ~42m57s
    09:47:22.039 INFO : Aud *CENC b0a48066-8d7a-4897-b17f-461d8cf862a0 | 64 Kbps | mp4a.40.2 | en | 433 Segments | Main |
    ~42m57s
    09:47:22.039 INFO : Sub 5ba639d3-fb81-49d2-ae10-846a000c0b23 | en-NZ | 1 Segment | ~42m52s
    09:47:22.040 INFO : Parsing streams...
    09:47:22.042 INFO : Selected streams:
    09:47:22.042 INFO : Vid *CENC 1280x720 | 2464 Kbps | de600d58-5173-46c0-884c-829e744a27e9 | 25 | avc1.4d001f | 429
    09:47:22.043 INFO : Aud *CENC a71f69ff-7184-4b10-8ad1-b63b4568b230 | 192 Kbps | mp4a.40.2 | en | 433 Segments | Main |
    ~42m57s
    09:47:22.043 INFO : Sub 5ba639d3-fb81-49d2-ae10-846a000c0b23 | en-NZ | 1 Segment | ~42m52s
    09:47:22.043 WARN : Writing meta json
    09:47:22.047 INFO : Save Name: My.Life.Is.Murder.S01E02.720p.TVNZ.WEB-DL.AAC2.0.H.264
    09:47:22.047 WARN : MuxAfterDone is detected, binary merging is automatically enabled
    09:47:22.048 INFO : Start downloading...Vid 1280x720 | 2464 Kbps | de600d58-5173-46c0-884c-829e744a27e9 | 25 |
    avc1.4d001f | Main
    09:47:22.048 INFO : Start downloading...Aud a71f69ff-7184-4b10-8ad1-b63b4568b230 | 192 Kbps | mp4a.40.2 | en | Main
    09:47:22.289 WARN : Type: cenc
    09:47:22.289 WARN : PSSH(WV): CAESEHF5AnbhfUhPig77n9aj/K4aDXdpZGV2aW5lX3Rlc3QiCDEyMzQ1Njc4MgdkZWZhdWx0
    09:47:22.290 WARN : PSSH(WV): CAESEHF5AnbhfUhPig77n9aj/K4aDXdpZGV2aW5lX3Rlc3QiCDEyMzQ1Njc4MgdkZWZhdWx0
    09:47:22.290 WARN : KID: 71790276e17d484f8a0efb9fd6a3fcae
    09:47:22.291 WARN : KID: 71790276e17d484f8a0efb9fd6a3fcae
    09:47:22.292 WARN : Reading media info...
    09:47:22.359 WARN : The entire file has been cut into small segments to accelerate
    09:47:22.361 INFO : Start downloading...Sub 5ba639d3-fb81-49d2-ae10-846a000c0b23 | en-NZ
    09:47:22.526 WARN : Reading media info...
    09:47:22.801 INFO : NaN: Subtitle, webvtt
    09:47:22.802 INFO : [0x1]: Audio, aac (mp4a), 192 kb/s
    09:47:22.802 INFO : [0x1]: Video, h264 (avc1), 1280x720
    09:47:22.802 WARN : Extracting VTT(raw) subtitle...
    09:47:22.811 INFO : Binary merging...
    09:47:28.231 INFO : Binary merging...
    09:47:28.461 INFO : Decrypting...
    09:48:07.123 INFO : Binary merging...
    09:48:27.024 INFO : Decrypting...
    09:48:36.410 WARN : My.Life.Is.Murder.S01E02.720p.TVNZ.WEB-DL.AAC2.0.H.264.mp4
    09:48:36.411 WARN : My.Life.Is.Murder.S01E02.720p.TVNZ.WEB-DL.AAC2.0.H.264.en.m4a
    09:48:36.411 WARN : My.Life.Is.Murder.S01E02.720p.TVNZ.WEB-DL.AAC2.0.H.264.en-NZ.srt
    09:48:36.411 WARN : Muxing to My.Life.Is.Murder.S01E02.720p.TVNZ.WEB-DL.AAC2.0.H.264.MUX.mkv
    09:48:40.170 WARN : Cleaning files...
    09:48:40.236 WARN : Rename to My.Life.Is.Murder.S01E02.720p.TVNZ.WEB-DL.AAC2.0.H.264.mkv
    09:48:40.500 INFO : Done
    D:\Downloads\Ozivine>
  22. I get the no sources found in response problem too with TVNZ. Same error as post 49.
    Using a VPN, but freevine works for TVNZ no problem. I can watch the show in my browser. I can get an MPD link with stream detector. But ozivine does not want to find anything. I am pretty sure my credentials are ok because it tells me that login was successful and token was obtained.
    I know you can't really diagnose a problem you can't reproduce, but that's at least 2 people who can't seem to get TVNZ working.
  23. Member
    Oct 2023
    Afghanistan
    Do you have a full colon ":" in your username or password by any chance ? That can give you the same error message as the login will get confused by it.
  24. Originally Posted by billybanana View Post
    Nope. The password has an ampersand, comma and exclamation mark, but no colon.
    The credentials work in freevine and I can log in using it, so they are valid.
  25. Member
    Oct 2023
    Afghanistan
    You've got your credentials added to the config.yaml in this exact format and spacing etc ?
    credentials:
      10play: username:password
      tvnz: username:password
    I know it's a stupid question but it could be as simple as that.
  26. Originally Posted by billybanana View Post
    credentials:
    With the exception that I still have the default 10play line above it with the comment '# Replace with your own credentials', yes, exactly as above. I tried removing the 10play line and the result is the same.
    I do get "Login successful, token obtained" but "No 'sources' found in the response". Exactly as it appears in post 49.
  27. Member
    Oct 2023
    Afghanistan
    Is this for any show ? What's a URL that you have tried ?
  28. Member
    Oct 2023
    Afghanistan
    I've pushed out a fix to the master which resolves this issue for all those shows you listed above.
    I also found some Comedy content is unencrypted. This fix will also grab that content now too.
  29. Originally Posted by billybanana View Post
    Legend, thank you
  30. Originally Posted by billybanana View Post
    It seems to be for any show. I tried the My Life is Murder episode as posted, and it failed. I just tried some other at random episodes:
    https://www.tvnz.co.nz/shows/colin-from-accounts/episodes/s1-e1
    https://www.tvnz.co.nz/shows/mary-and-george/episodes/s1-e1
    The no sources message comes back pretty fast so it's not like something is timing out. Looks like something is just downright being rejected but I can watch the episodes in my browser no problem.
    Perhaps you could add some sort of --debug mode printing out all sorts of info to see what's gong on.
